ardi's avatar
ardi
Towing a scooter
Any recs on what I could use to tow a small (under 200 lbs) scooter behind a class A. Preferably a hitch mounted one.
  • Vesahaul. About 89lbs, 600lb weight limit, plus you can still tow a toad under 3000lbs Comes with ramp for one person easy loading. Might be overkill but leaves room to grow.
  • Trackrig wrote:
    A $125 scooter carrier. Maybe get a cover for it also.
    Clicky
    Bill
    WOW, I paid a lot more than that for my steel one.
    bumpy
  • I have a Travelrite rack and i'm happy with it. See:clicky
    Some features:
    It comes with a simple anti rattle hitch bolt that works!
    Has a center tie down so there is one less bar to whack your shins on.
    Relatively light, like 35 lbs.
    States only two straps needed, I still use four.
    Other stuff:
    If you have a center mounted spare, you will probably need a hitch extension.
    The standard rack for years is probably the VersaHaul. It's very heavy and you don't need that for a small scooter.
    Norm
  • What do you mean by "a small scooter"? Is it a battery powered scooter for someone with walking problems that will have electronics that shouldn't be out in the rain, or is it a motor powered scooter that can handle the elements?
    I would think a small used enclosed trailer.
    Bill
  • I did mean a platform, hitch mounted. I have been looking online and there are few available, any recs on which ones are good/bad?
  • Fastest way to ruin a scooter, get a small trailer or a hitch mounted platform to carry the scooter.
    navegator
  • If by tow, you mean having the wheels of the scooter on the ground?...I wouldnt advise that.
    You could have a platform to have it up off the ground that fits into your hitch.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jan 17, 2025
