- OutdoorPhotograExplorer
32vld wrote:
Example you have a pickup rated to tow 9,500 lb.
You have a trailer that weighs 2,000 lb and is rated
to carry an 8,000 lb load. So the trailer and load is
10,000 lb.
Is it legal to tow the trailer empty?
Is it legal to tow the trailer with 7,500 lb load?
The range of answers is interesting since I read your question to ask not about exceeding the actual rating but rather can you pull a trailer that has a GVWR that exceeds your TV's rating. If you are towing a flatbed trailer that weighs 2,000 lbs, you are within limits even if the same trailer is rated for an 8,000 load. You're towing 2,000 lbs, not 10,000 lbs.
To your question on 9,500 lbs, as noted you would need to evaluate tongue weight, cargo limit of the tow vehicle, axle ratings etc. Also, I wouldn't want to tow at 100% of tow rating. - JIMNLINExplorer III
10,000 lb.
Tow rating aren't a enforceable number from a legal standpoint...meaning road side dot doesn't use tow ratings..... for anything.
Nothing legally says you can't tow a higher rated trailer above the truck makers tow ratings. However if the tow vehicle is a small v8 or a v6 then the vehicle will struggle along with the operator especially on a all day run.
Now if the tow vehicle is say a new gen diesel with a 400 hp/900 ft pounds torque then its a enjoyable tow.
Towing legally is smart/safe.......towing illegally is really dumb and unsafe. - mkirschNomad II
debraindi wrote:
So If somebody rams my rv from behind and and I'm 50 bls over my insurance company could say I was over loaded because my rv didn't stop in time, like the soso where replaying to.
No, because your RV's contents would be splattered all over the road and there would be no way to weigh it accurately.
Also no, because the person that rear-ends you is the one at fault.
Why would "didn't stop in time" have anything to do with a REAR END collision anyway? If you stopped sooner, they would've rear-ended you harder! - chracatoaExplorerThis type of thread comes up every time here. I don't remember a single web link to a real accident where the driver was prosecuted or sued due to his/her RV weight. The links in this thread are for trucks and the scale mentioned was also for trucks (they don't want them destroying the local roads).
- BedlamModerator
naturist wrote:
Many, many things are legal and stupid. Many good ideas are also illegal. Wisdom counsels avoid both illegal and stupid.
Then you have regional laws that conflict with each other. Examples: Maximum length, width or height, Maximum trailer weight with no brakes, Double towing, Double towing behind a hitch ball trailer, vehicles register by Manufacturer GVWR or some other method, ... - BenKExplorer
Most civil, both settled out of court and court decisions, has NDA's
Especially OEM's, who settle out of court because it is cheaper...bad PR
and of course tight NDA's with teeth... - atreisExplorerSo long as you are not exceeding any axle or tire rating, it is legal to tow the trailer in both cases. Whether or not it's safe depends primarily on how it's loaded and hooked up. (Improperly hooked up or loaded, the empty trailer could be just as unsafe as the full one.)
The only legally enforceable weight ratings are axle and tire ratings.debraindi wrote:
If you are rammed from behind, the problem isn't that YOU didn't stop in time - it's that they didn't stop in time. Also, rear-end accidents are the fault of the person doing the rear-ending, by convention, unless there's documented evidence of something odd happening (like non-functional brake lights - hard to prove after the accident).
If you're overloaded and don't stop in time, you'll still likely only get charged with "failure to assure a safe clear distance". (In other words - you need to know how long it takes you to stop and make sure you have that much room.) Trucks, trailers, brake systems, vary considerably - a trailer combination well within margins can require more distance to stop than one that is many lbs over if the latter happened to have better brakes or the TV had better brakes (better adjusted, newer, stronger, whatever...). - gtnsmlrExplorer
rockhillmanor wrote:
And that NEVER happens. First the trailer in question would have to be weighed at the scene to prove it was over weight. Not a good way to do that.
Ohh but they CAN and DO!
I have seen DOT pull out their portable scales time and time again right in front of my house, when some of the big trucks decided to use our street to skirt the interstate scales.
Portable and can weigh the big boys so my guess is that they can easily weigh a TT if called in to do so.
Well, that does raise a question. Just how do you weigh an RV that is on it's side in pieces with it's contents scattered a 1/2 mile down the road? - BenKExplorerDepends on the severity of the accident. In dollars damage, major injury to death(s)
That then is split between criminal and civil
I don't like to use lawyers, but there is a time, place and need for them
It will cost to get to the approx weight range and why think depends...like the
reconstruction of an airplane blown out of the sky, or just that a plane fell
out of the sky...that kind of stuff see on the news all the time where they have
reconstructed the vehicle
Can get a good idea of what it was before...base line would be the OEM brochure
listed 'dry' weight and then go from there - carringbExplorer
Easy. Scoop it all up with a front end loader, put it in a truck or dumpster, weigh it, subtract tare weight. It's not rocket surgery. Even our sweeper at work has a built-in scales, if the debris were really that scattered.
Looking for advice before your next adventure? Look no further.25,102 PostsLatest Activity: Jan 18, 2025
