- JIMNLINExplorer III
32vld wrote:
Example you have a pickup rated to tow 9,500 lb.
You have a trailer that weighs 2,000 lb and is rated
to carry an 8,000 lb load. So the trailer and load is
10,000 lb.
Is it legal to tow the trailer empty?
Is it legal to tow the trailer with 7,500 lb load?
Tow rating aren't a enforceable number from a legal standpoint...meaning road side dot doesn't use tow ratings..... for anything.
Nothing legally says you can't tow a higher rated trailer above the truck makers tow ratings. However if the tow vehicle is a small v8 or a v6 then the vehicle will struggle along with the operator especially on a all day run.
Now if the tow vehicle is say a new gen diesel with a 400 hp/900 ft pounds torque then its a enjoyable tow.
Towing legally is smart/safe.......towing illegally is really dumb and unsafe. - OutdoorPhotograExplorer
10,000 lb.
The range of answers is interesting since I read your question to ask not about exceeding the actual rating but rather can you pull a trailer that has a GVWR that exceeds your TV's rating. If you are towing a flatbed trailer that weighs 2,000 lbs, you are within limits even if the same trailer is rated for an 8,000 load. You're towing 2,000 lbs, not 10,000 lbs.
To your question on 9,500 lbs, as noted you would need to evaluate tongue weight, cargo limit of the tow vehicle, axle ratings etc. Also, I wouldn't want to tow at 100% of tow rating. - debraindiExplorer
carringb wrote:
So If somebody rams my rv from behind and and I'm 50 bls over my insurance company could say I was over loaded because my rv didn't stop in time, like the soso where replaying to.Terryallan wrote:
Campfire Time wrote:
There is another issue here that is often overlooked. Civil liability. We live in a highly litigious society. It's why we all have to carry umbrella policies. Should you get into an injury or death related accident, even if not your fault, if it's discovered that you were towing weight over the manufacturer's set limits, you are setting yourself up to be sued. Yes your insurance will cover you. Then drop you like a hot potato and put you on a blacklist.
And that NEVER happens. First the trailer in question would have to be weighed at the scene to prove it was over weight. Not a good way to do that. Second. manufacturer's weight ratings are NOT law. they are warranty limits only.
Actually there is case precedent. Many cases. Also accident reconstruction vans do carry scales that I've seen. Being legal is only one factor considered for liability. Reference standards are often cited as well (i.e. SAE, ASME, FMVSS etc). Granted, being over on GCWR only is unlikely to be a red flag, but exceeding tire, axle, or hitch ratings could be a violation of one or more of those reference standards.
Here as 6 cases here. Most were work-related, however the last case was recreational.
http://www.hardworkingtrucks.com/improperly-equipped-pickups-costing-businesses-millions-in-lawsuits/ - jerem0621Explorer III am not an attorney, but these threads really crack me up.
I've said it before and I will say it again...
If you cause a wreck you are liable. You don't get a free pass because you were under your weight limit.
Officer...." Sir you caused the accident"
Sir..."But I was under my GVWR, GAWR, And GCWR."
Officer...."Oh, that changes everything...no charges...good job for being under your weights."
This has never ever happened...if you wreck someone you are liable. Ratings be darned.
Similar to the Toyota chief engineer for the Tundra said...it's all about the operator...ratings are there for the guy who doesn't really know how to load a truck and pull a trailer.
It is up to the operator to operate the vehicle safely...overloaded or within the ratings. I don't care if your truck is rated to tow 25k lbs if you are not personally capable of handling that rig your trucks ratings don't mean a darn thing.
Thanks!
Jeremiah - IdaDExplorer
Terryallan wrote:
And that NEVER happens. First the trailer in question would have to be weighed at the scene to prove it was over weight. Not a good way to do that. Second. manufacturer's weight ratings are NOT law. they are warranty limits only. Auto makers do not write law.
And as has been asked on this site a million times. Give a real world example of someone being sued because their TT was too heavy. There are none.
And My brother's wife's brother's friend had a friend that had a friend that knew a guy who had a brother who knew a guy who got sued. That don't count. Has to be first hand knowledge
You brother's wife's brother's friend's friend must have told you that it never happens. This isn't rocket science, if you don't understand how civil suits work, then you don't get the reality of what we're talking about here. Fact of the matter is that it happens more than you think. Most civil suits are settled out of court and never see a judge which is why you rarely hear about them.
Moreover we're not talking about criminal law here. Civil liability has nothing to do with "law". They are about willful negligence and do not require the same level of proof as a criminal case. Civil suits only have to show probable liability and if brought to a jury only require a majority of the jury to agree on a verdict. This is the reason most are settled outside of court.
In the case of towing beyond your rated capacity any lawyer would have a field day with that. It's not illegal for a fast food joint to serve scalding hot coffee either. But someone sued over this issue and won. The case of an overweight trailer is cut and dry and quite obvious. No jury is going to side with you because you say "lots of folks on rv.net tow overweight". All they will see is that the manufacturer said "Do not exceed xxx # of pounds". And lawyers well know this.
I'm a lawyer and I used to practice at an insurance defense firm, so I know a bit about bad drivers and bad doctors and how these cases tend to work.
My take on the civil liability angle is that it depends on the situation, but in the RV world towing a reasonable amount overweight is generally going to be a non-issue unless you're way over.
For one it's going to be difficult for a plaintiff to accurately prove what a travel trailer weighed at the time of the accident - it isn't like a load of pavers where it's easy to fix the weight by matching up a receipt.
Second, the plaintiff would need to not only accurately establish that the trailer was heavier than the manufacturer weight ratings, but would also need to establish that exceeding those ratings actually caused the accident and injury. That would take a lot more than Matlock whipping out a copy of the payload sticker in front of a shocked jury.
The reality is these cases involve a multitude of factors on both sides and almost all of the time they settle. It's possible that being overloaded could be one of the factors in play, but it would be very unlikely to ever be a deciding factor in fixing liability or damages and frankly in most cases I don't see it being a particularly important factor. Again assuming the bad driver is at least within the realm of reasonable behavior with what he's towing.
Just my two cents. - TerryallanExplorer II
Ohh but they CAN and DO!
I have seen DOT pull out their portable scales time and time again right in front of my house, when some of the big trucks decided to use our street to skirt the interstate scales.
Portable and can weigh the big boys so my guess is that they can easily weigh a TT if called in to do so.
Yes they can. IF the TT, and it's contents are NOT scattered all over the road. - TerryallanExplorer II
In the case of towing beyond your rated capacity any lawyer would have a field day with that. It's not illegal for a fast food joint to serve scalding hot coffee either. But someone sued over this issue and won. The case of an overweight trailer is cut and dry and quite obvious. No jury is going to side with you because you say "lots of folks on rv.net tow overweight". All they will see is that the manufacturer said "Do not exceed xxx # of pounds". And lawyers well know this.carringb wrote:
Much obliged on the links. Some folks just don't want to face up to reality and find this stuff out for themselves.
Read the links, and NONE of them have anything to do with RVing, and even the one that is about boats is commercial.
Again. While I don't suggest towing above the capacities. Never have. There are no law suits to threaten folks with, as they pertain to RVing. Show us one.
Truth is, anytime you have an accident. You are liable for the damage IF you cause it. Over weight or not. - naturistNomad IIMany, many things are legal and stupid. Many good ideas are also illegal. Wisdom counsels avoid both illegal and stupid.
- Campfire_TimeExplorer
Much obliged on the links. Some folks just don't want to face up to reality and find this stuff out for themselves. - fla-gypsyExplorerI don't answer legal questions because I'm not an attorney but towing safely dictates following manufacturers written/published "do not exceed" limits on all aspects.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 15, 2026
