Leno's avatar
Leno
Towing a trailer
I would like advice on pulling a trailer with gross weight of 11,060 with a 2001 31 ft class C with a V10 engine?
Since writing this I realized the truck weight was included in this weight.. Trailer is only 7000 lbs.
Thank you all for your input. Made me look into this more!
    No way!
  • Your way, way over the tow rating.
    Strongly advise against it.
  • Check the specs on your unit, but most Class C's are only rated for somewhere between 5000lbs and 7500lbs for their towing capacity.
  • Sounds like a lot of wt to be pulling with a motor home.but you haven't said the tow rating of the motor home either.
Looking for advice before your next adventure? Look no further.25,191 PostsLatest Activity: Apr 04, 2026
