rhagfo
Aug 10, 2013Explorer III
jaycocamprs wrote:gamma3116 wrote:
I notice the pin box doesent move. It the body of the trailer. You can see were the body rubs on the pinbox as it teeters up and down, when it gets bad.
I would look at the frame around where the pinbox bolts up. This is a known problem area on Keystone 5'vers with Lippert frames. You should not have movement in this area.
X2
If it is rubbing it is beyond maybe a little flex of the front cap, time to checkout the frame at the pin box. I assume you have owned the 5er since new.
Looking for advice before your next adventure? Look no further.25,204 PostsLatest Activity: Aug 13, 2026
