JBarca
Jan 05, 2014Nomad II
I have had parts of that truck.. I say parts as I had the engine in a 2002 Tahoe towing my smaller camper. It was a good engine, I only had the 3.73 rear axle.
The Burb, I have weights off of a 2001 1500 Yukon XL 2 x4 drive which would be close to the one you are referring to. That truck from scaled weights was 3,040# front axle and 3,100# rear axle with full gas and no one in it.
You stated the one you are looking at was 4 x 4 so add ~ 200# to the front axle.
Do not know what TT you are looking at, heads up about loaded TT tongue weight. The Burb is a good kid hauler and that means more cargo weight plus the loaded camper TW. It is not hard to have a 750# loaded TW and people on board and max out the GVWR on the Suburban.
If you have a specific camper in mind, it is easier to help tell if the Burb is a good match or not. The Burb is a good truck, but all within it's limits. The 4.10 rear axle is a bonus, but watch the loaded camper TW.
PS I have had a 2003 K2500 Suburban, really good truck but that is a lot more truck than the 1500. Again depending what you want to do with it.
Hope this helps
John
Hope this helps
John
Looking for advice before your next adventure? Look no further.25,204 PostsLatest Activity: Aug 13, 2026
