blt2ski
Jan 06, 2014Moderator
The problem with a cutting agent in the oil......is once and if these area;s are clean, could another issue pop up. Probably best to rebuild or put a new LB in the thing, then you know what you have. OR, as you have noted, go to a newer burb that hopefully does not have any issues........rebuilding the old motor might be the better option in this case.
Marty
Marty
Looking for advice before your next adventure? Look no further.25,204 PostsLatest Activity: Aug 13, 2026
