BenK
Jan 06, 2014Explorer
OP is asking for personal preferences...
Mine is to keep a known entity vs spending more money on an unknown...even
a new vehicle never owned before
First, your El Cheapo replacement...indicative of either or both neglect
from the previous owner(s) and/or laid around un-attended for a while
The chances of it going south is GREAT, IMHO. Any cleaning fluid will
both have the potential of the gunk floating around to cause a problem
somewhere else....or that during the cleaning, it allows something going
metal to metal...and...continue to a bit after it is flushed out...there
will be some of that stuff left in there. Albeit diluted by the fresh
charge of engine oil
Your 1998 is a GMT400. GM has truck 'platforms' from which they derive
SUVs and others (CUV's are from car platforms)
Here is the Wikipedia explaining GM platforms: GM GMT platform outline
A 2004 is a GMT800. Much better 'car' attributes and continues in the
GMT900 and into the GMTK2xx (assume, as I've not checked out the 2014's yet)
Note that my opinion(s) is in the vast minority here. My trucks (includes
SUVs) are for 'working' or 'towing'. Although I did commute for over
7 years with my GMT400 K3500 Suburban (it's a 8.6K GVWR, but ordered
it with the F60 option...1 ton front snow plow prep package and
the rear axle is the exact same as the 1 ton dually of that year..except
for the brake cylinders and MC). That ride quality is NOT on my
have to have list, but at the bottom of my nice to have list
Once on the highway, there is little difference in ride quality
and noise between my GMT400 and GMT800/GMT900, IMHO. It is in the
rough that the 'nicity' of the newer shows and again, I bought my
trucks as trucks, not for car like. I've gotten 15.4MPG pure highway
with my 7.4L, but normally pure highway is in the 12.x range...but
I'm a boy racer and mostly 'into it' :B
Newer normally begets less worn everything, but assumes a kind previous
owner(s) that did not beat it up, and used the manual maintenance
schedule/materials
Anytime an engine is pulled, I recommend rebuilding the automatic.
Ditto liking the GMT400 over the new models...check out my sig and pic
of my Sub
So back to your question: decide what you 'want' & 'need' out of this
If you wish a nicer ride and updated amenities, then get the GMT800.
If you like the GMT400, then get a Mr Goodwrench engine and tranny
Or consider a performance 5.7L and headers. That makes a huge difference
and some over at my old Suburban forum reports 20MPG with 3.73's and
OEM tire OD
That will be less $$$ than buying a used GMT800, but the GMT800 WILL
be nicer riding. Also note that GMT800's and newer are a bit smaller
interior.
Almost forgot...GMT800's receiver is junk. If the previous hasn't,
and you buy one, change it with a traditional receiver. About $150-$200
plus about 1 hours labor
Good luck and report back on how it goes on this thread
schedule/materials
of my Sub
OEM tire OD
interior.
Looking for advice before your next adventure? Look no further.25,204 PostsLatest Activity: Aug 13, 2026
