I am new to trailer camping and towing. I have a 2008 Suburban with a 5.3l. It is rated to pull up to 8100lbs. The camper i am buying weighs 7300lbs. The suburban has the towing factory package wi...
Prolly means, You need more truck. By the time you load that TT. You will be over loaded. And while you can add power. And adding power is really spendy. Not much you can do for the GVWR of your TV. And there is a real good chance you will be over the hitch rating as well.
Is it safe. IF you get the it setup perfectly, and you are not over your hitch capacity. prolly so. Will it wear out your TV faster? Yep. Will you enjoy towing over your capacities. Up to you. But I doubt it.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
