I am new to trailer camping and towing. I have a 2008 Suburban with a 5.3l. It is rated to pull up to 8100lbs. The camper i am buying weighs 7300lbs. The suburban has the towing factory package wi...
There are probably as many weekenders out there, towing over at least one limit, as there are people towing within limits. If the hitch is strong enough, it will likely tow the trailer. As for staying under the speed limit, most ST trailer tires are rated 65 mph max. In your case 60 mph towing may be best.
Make sure your trailer brakes work well, and watch tow vehicle fluids, temps, tire pressure, etc.
Being an extra cautious, safe driver, may help some too.
Jerry
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
