falc's avatar
falc
Towing Advice
I am new to trailer camping and towing. I have a 2008 Suburban with a 5.3l. It is rated to pull up to 8100lbs. The camper i am buying weighs 7300lbs. The suburban has the towing factory package with has 8 pin connector, and i believe the tranny cooler.. I am adding the brakes and the anti sway.
My questions are.
1. Am i safe to pull this?
2. is there precautions i should take
3. What can i do to make my truck pull better?
Any help is greatly appreciated.
  • besides getting a new vehicle how can i add towing power to it
  • That 8100 pound rating is for a bare bones vehicle with one 150 pound driver. Once you load your family the 1500 series suburbans are honestly hard pressed to get out of thwir own way.
  • The hitch does look like it is integrated into the frame of the suburban. If it says 8100 and i am few pounds over once the camper has stuff in it, does that pose a dangerous issue. I have heard that the manufacture always errors on the side of caution and puts the number a little lower.
  • I am sure someone will tell you to make sure that the weight you are talking about is real weight, not just the "dry" weight.
    One thing you need to look at is the hitch on the Suburban. The hitches from the factory are notoriously weak - maybe a 5000 pound weight rating. There were some model year Burbs that had the hitch integrated in, and were very difficult to upgrade the hitch. Hopefully your Burb is not that MY.
    I have an 03 Burb. I upgraded the hitch to tow my 6500 pound boat. It was honestly shocking how flimsy the factory hitch was. And my Burb is a 2500.
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Dec 22, 2025
