schaalk's avatar
schaalk
Towing Advice
I have a 2016 Ford F-150 4 x 4 with 2.7L Eco Boost engine, 3.73 axle, and trailer tow package. GCWR is 13,000#, GVWR is 6500# and tow capacity is 8,000#. The trailer I am looking at is 6,500#s dry/empty. Weight of all passengers, full gas tank plus stuff in truck bed should not exceed 855#s and no more than 500#s added to trailer while towing. All of the numbers keep me under the 13,000# GCWR. Can I tow this trailer safely or should I be looking for a lighter trailer?
  • You could put a 7000# car on a car dolly and tow that, tongue weight should be fairly light. Tow ratings are just that, tow ratings.. what you can tow.. NOT what you can carry which has to be factored in.
    It's not really a nonsense number IMO, just that people misinterpret what it means (and I'm sure the auto industry doesn't help with that).
  • Loaded that trailer will be pretty close to 8,000# or more. This means a tongue weight of over 1,100# {including the WDH}. Your hitch probably is not rated for that and you'll probably be over your rear axle limits as well. The biggest problem will be running out of payload. Most 4X4 half tons are notoriously short in that category{especially if they are crew cabs}, and very few can actually tow their "towing capacity" a nonsense number {much like dry weights}.
    Having 1,100+# of tongue weight doesn't leave much for bodies and gear so unless you are prepared to leave just about everything/everyone home.... yes, you might want to consider a lighter trailer.
    As always.... Opinions and YMMV.
    :C
Looking for advice before your next adventure? Look no further.25,149 PostsLatest Activity: Jul 17, 2025
