brioux1 wrote:
2014 Ram 1500 Big Horn 5.7L Hemi w/ Tow package Crew Cab 6'4" box
From The Sicker on the door:
GVWR 6800 LB
GAWR Front 3900 LB
Rear 3900 LB
Info- Tire and loading
combined weight of occupants and cargo should never exceed 1070 lbs. (this one confuses me)
From Manual:
Towing- 10,000 lb.
Payload- 1520 lb.
If I have left out any relevant info please let me know. I am a little new to this so I may have missed something.
Finally, I will be traveling with my wife and two young children. Basically I just want to know what weight of TT I should be looking at.
Any help will be much appreciate
Thanks
The payload number from the manual is a generic payload for a base model truck. Actual payload varies, depending on installed (4X4, crew cab, etc) options. F150, for example, has versions with payload anywhere between 750 lbs and 3200 lbs. They all carry the same manual.
The max occupant / cargo number, from your door post, is the payload for your specific truck, as it was configured when it left the factory. Any weight added buy a dealer (bed liner, floor mats, undercoating, etc) or the end user (bed covers and accessories), reduces that number further.
Your payload gets eaten up by weight of people, pets, cargo (in the truck), weight distributing hitch (80 - 100 lbs), and trailer tongue / hitch weight.
If you know what your available payload is (1070 minus weight of added options and accessories, minus weight of WD hitch, minus weight of family, minus weight of truck cargo, equals available payload), divide that number by .13. That will give you a ball park figure for max "loaded" trailer weight.
RV sales people have no idea what you're going to load in your trailer, so, many of them base their recommendations on unloaded weights (including tongue weight) of the trailers. You can get a rough idea of loaded weight by adding 800-1000 lbs (average load of camping gear, bedding, dishes, groceries, water, etc) to the unloaded trailer weight.
Average tongue weight is 12.5 percent of loaded trailer weight. Based on what you load, and where (in relation to axle location) you load it, tongue weight goes up and down during every trip. Water and groceries get used up, holding tanks fill up. On my trailer, advertised tongue weight is 880 lbs. During a camping trip, my actual tongue weight can be anywhere between 975 and 1100 lbs.
Here's a link that may help.
