I am looking at buying a new TT and want to make sure I am looking at models I can tow safely and easily. I understand I will need a Weight Distributing Hitch. To be honest I've had a hard time gettin...
Personally in the past I have not worried about going a few hundred pounds over my previous 1/2ton payload as long as I was within the tire and all axle ratings. For such a small difference (300lb vs 600lb) I would have done it in my personal case but that is up to you. Especially when you are well below the GCWR of the truck-trailer combo. Just remember that should be actual hitch weights, not imaginary low numbers in the brochure.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Mar 13, 2017
