I just bought a Reflection BHTS says in specs the trailer is GVWR is 9995 lbs and hitch weight of 997 lbs. I also have a 2017 F150 Super Crew Cab V8 5.0l engine. Ford satates it has 11,000 lbs towin...
All I can say is good luck with it... You already have the truck and the trailer, so hitch it up, take it to the scales and find out some real world weights...
I guess if you are only going to go some 27 miles with it, you'll get down the road with it..
Not sure where you got the #11000 tow rating with the 5.0, but it's the 3.5 Ecoboost that has the highest tow ratings, even in 2017.
Again, good luck with it..
Mitch
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Aug 28, 2026
