I just bought a Reflection BHTS says in specs the trailer is GVWR is 9995 lbs and hitch weight of 997 lbs. I also have a 2017 F150 Super Crew Cab V8 5.0l engine. Ford satates it has 11,000 lbs towin...
OK, as was stated. 8500lbs empty will weight near 10k lbs loaded for a trip! being a bunk house I`m going to assume you have kids, so yes it will weigh that much. that will put tongue weight at 1200lbs (12%). To put that in perspective I`m towing a 7100lb dry trailer that weighs in at 9200lbs loaded for a trip with an Excursion with a V-10 and 4.30 gears. You wont be happy with how it tows or its performance.
Good luck!
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Aug 28, 2026
