Paull6
Apr 18, 2017Explorer
Towing Advice
I just bought a Reflection BHTS says in specs the trailer is GVWR is 9995 lbs and hitch weight of 997 lbs. I also have a 2017 F150 Super Crew Cab V8 5.0l engine. Ford satates it has 11,000 lbs towin...
wowens79 wrote:
If the 27 miles is relatively flat, and lower speeds, it probably does not tow too bad. If it is mountainous, or interstate, I don't think it would be very pleasant. My 6.0 gasser with 3.73 gearing definately knows when it has out 8000lb (loaded) camper behind it on the highway of in the mountains.
I like to go different places, so I'd not be happy staying at the same place all the time and would want to venture out. Hitting the mountains, and the highway I think the towing experience won't be the best.
