HydrogenCyanide's avatar
Jan 14, 2021
Towing Advice
I have a 2017 3.5L Ecoboost. Per the door sticker, its payload is 1670 pounds. I have always used a Equalizer hitch
Prior to this past summer I had a 2014 28RBS Cougar that had Dry Weight of 6700 pounds and a hitch weight of 955 pounds. This combination towed perfectly. Close to 6000 miles without an issue.
This summer we purchased a 2020 Sporttrek Touring312VBH. Dry Weight of 7800 pounds and hitch weight of 1,020 pounds. Using same tow vehicle and same hitch.
The experience towing between the two is night and day difference. The dealer re-setup the hitch but that may be where my issue is. Nothing to do with power, I just feel much less stable and feel the trailer tossing me all of the road.
Could it be the hitch? Would I be better of going to an Anderson? Could the hitch just need further adjustments? Is this relatively minor increase in trailer size enough to warrant me needing a larger tow vehicle?
Any advice would be appreciated.
Thanks
Marc
  • valhalla360 wrote:
    Since you have the rig already, next time out (fully loaded ready for camping), swing by a CAT scale and get the real weights. Take the time to get 3 weights:
    - Hitched with the WDH connected.
    - Hitched with the WDH disconnected.
    - Unhitched just the truck.
    The compare that to the weight ratings to see where you really stand.
    For HydrogenCyanide, here's a write-up about getting these 3 weights and what to compare them against from a ratings perspective:
    https://learntorv.com/weigh-rv/
  • Not sure about the equalizer hitch, but my Blue Ox has different spring bars for different tongue weights. Could you need to change those out??
  • enblethen wrote:
    Another thing to check is tire pressures. Close to gross vehicle comnination would need tires maxed out on air.
    X2
  • Another thing to check is tire pressures. Close to gross vehicle comnination would need tires maxed out on air.
  • bgum wrote:
    It is most likely you have exceeded the capacity of the tow vehicle.
    Could be a combination:
    - How many people and what cargo is in the truck?
    - How is the hitch set up.
  • It is most likely you have exceeded the capacity of the tow vehicle.
  • Yes, it could be hitch or truck setup.
    What is make and model of hitch?
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: May 03, 2023
