waltrazz's avatar
waltrazz
towing advise please
hello, towing my 38 ft travel trailer close on 10,000 lb with my f150 heavy towing package and i added air bags so it sits nice and level with 15 lbs in bags. tows petty good at 50 to 55 mph tops , but once a while i feel the tail wag and it calms down quickly but i don't like it . so hears the question will i improve by experience by replacing the truck with an F-350 or similars with dullies. thanks for looking .
  • Even a 3/4 ton would be a nice upgrade. They start with a payload north of 2500lb.
    What's the payload on the door sticker of your current truck? The trailer should have a hitch weight of around 1200-1400lb, so even with the towing package you are likely pushing the limits of the trucks payload.
    Honestly, I wouldn't go much over 7-8000lb trailer with a 1/2 ton and many won't even handle that much.
  • I would say yes even without the dually as 10k should not be an issue for a 350/3500 SRW.
    I am a far cry from the weight police crowd but my personal opinion and only my personal opinion is 10k is too much for any half ton regardless of its tow rating or payload rating, that could approach twice the weight of the tow vehicle. 350/3500's additional weight, suspension, brakes etc will certainly help add to the stability and safety factor. I realize that some 1/2 tons have higher tow ratings than 10k but a travel trailer/fifth wheel especially 38 feet long is going to behave differently than a flatbed trailer loaded to the same weight with say concrete bags or whatever equipment unless you have built a big box around it. I know on my 3500lb equipment trailer loaded down with a 9000lb skid steer tows better than my fifth wheel (10k lbs) even though it weighs 20% more.
  • Short answer, yes. Even with a heavy duty F-150 you still have way too much trailer for that truck. It's the tail wagging the dog. Towing is one consideration, stop g it is another. I can't imagine what a windy day on a winding road would be like but it probably wouldn't end well.
    The good news... new trucks are nice. Good luck.
    :C
