- Eagle1951ExplorerIt fits inside of CR-V.
- I guess I glossed over the part about 'mini' golf cart. I was thinking of a full size electric cart weighing over 1000 lbs. You'd still have a ton of tailswing, ever thought of hauling the cart on the back of the CR-V on a standard hitch rack?
- Eagle1951ExplorerMotorhome is 34 ft. on Ford F-53 chassis. Cricket weighs about 300lbs and will fit in the back of CR-V to haul it but thought hauler would be big plus over loading car each time
- Had to look up and see what a Mighty Hauler was... I'm not sure exactly what your motorhome is, but if the frame is strong enough and you have at least 2,000 pounds of reserve capacity on your rear axle it might work. With the amount of tailswing you'd have, strange things might happen with your toad on tight turns.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
