spol11's avatar
spol11
Towing camper with van. What rating hitch should I purchase?
Tow vehicle: 2013 Nissan Quest SV 6 cyl.
Max tow capacity: 3500#
Torque: 240 ft/lb
RV: 2000 Trailmanor 2720 SL
Dry weight: 2875#
Payload cap: ~1210#
Hitch weight: ~392#
In the van will be my wife and two young kids.
Van dry weight: 4400#
So, vehicle weight + load/passenger = approx. 5000#
I'm looking at whether a class 2 or class 3 trailer hitch would be more appropriate. As well as whether a weight distribution hitch might be an even safer idea.
Thoughts on safety of pulling this pop up/expandable camper with my van??
  • spol11 wrote:
    Thanks for the replies everyone! Definitely good feedback. I figured class 3 was better option but this solidified my choice.
    I also knew that I was going to be maxed out (or very close) with supplies in camper/van but some of your info has me thinking I need to just purchase a truck with better towing capabilities sooner than later. The last thing I want to do is ruin the transmission on my wife's van in a year or two of camping.
    (sorry for the cross post).
    There aren't any hybrids with a dry tongue weight under 350lbs. The Rockwod Roo line of hybrids, are the best selling hybrid line and the most floorplans. Their smallest Roo 19 has a fictitious dry tongue weight of 448lbs. That's with no battery, no factory options, no water and no cargo.
    Popups or A-frame trailers are pretty much all you can tow with that. It's the 350lbs max hitch weight that's the biggest issue.
  • Good input bikendan.
    I have found that the tongue weight on this particular trailer is about 390#. Obviously that still exceeds the van's max TW.
    Would a weight dist. hitch help at all??
    or is it as simple as TW cannot exceed TW capacity of towing vehicle? thanks in advance.
  • valhalla360... I'm trying hard to get someone to tell me everything will work out great and my setup is fine :)
    At this very moment, a truck is unobtainable. But after going through my math numerous times and getting great feedback on this forum, I'm quickly realizing a used truck will likely be in my driveway by next year.
    a WDH will not lower tongue weight, it just shifts it. and is that 390lbs the actual weighed tongue weight or a brochure/website "dry" tongue weight? and we haven't even discussed the van's payload capacity.
    You can get a reliable 4 door pickup that will easily handle that trailer pretty cheap.
    Our current 2008 F250 4 door was only $10k and we've had it for 2yrs with nothing but standard maintenance (not that you need a 3/4 ton). Our previous 3/4 ton was only $6k. Reliability has never been an issue buying at around 10yrs old (current truck is really clean but body rust can be an appearance issue)
  • Bikendan, that was dry TW. I've redone my math.... I would have to somehow keep my van/trailer payload at/under 300# to be safe and that's just not happening. And the TW is an immediate issue, so that van wont be pulling anytime soon.
    Valhalla360, I have already started looking. I'll be back in the forums with more questions once I get a proper TV.
    Yep, the 350lbs max hitch weight is the main weakness for minivans, then the 3500lbs towing capacity.
    That's why Popups, teardrops and A-frames are about the only choices.
