Birdie1025's avatar
Birdie1025
Towing Capability
Here is the data I have:
2013 Ford F150 FX 4x4 with 5.0L engine
Axle Ratio = 3.55
Max Loaded Trailer Weight = 7,700 lbs (F150 Towing Guide)
GCWR = 13,500 lbs (F150 Towing Guide) Sticker on Left driver door shows a GVWR = 7,350 lbs
Dead Weight Hitch = Max Tongue Wt = 500 lbs (F150 Vin Decoder)
Travelers Weight for us = 120 lbs. + 150 lbs + 85 lbs (dog) + 35 lbs (dog)
Found a good deal on a 2006 Eclipse Attitude T19FK Toy Hauler. I am having trouble finding information on TH. What I am finding is Hitch Weight = 650 lbs and Cargo Weight = 5,000 lbs.
To help aid in the process - Live in the midwest (IN) and see mostly traveling around the midwest as of now. This will be the first TH so I don't honestly now to answer that question at this time.
How do I take all that info and confirm that my 1/2 ton truck can handle the TH listed above. If it can't handle that what should be my cap I should be looking for in a TH.
Any help would be greatly appreciated.
Thanks,
  • Missing data: truck payload. Also, you need to add to the mix the weight of a full tank of gas, which will increase how much your projected payload weighs.
Looking for advice before your next adventure? Look no further.25,158 PostsLatest Activity: Jul 30, 2025
