Bglov's avatar
Bglov
Towing Electric Cord Damage
I have a slight slice in my tow cord electice cable from a pinch that happened while towing. The wires look to be in tact but my brake lights are not working though the other lights do. Do I need to replace this cord and how involved is that?
  • petrel wrote:
    TucsonJim wrote:
    I'd just slice open the umbilical, make a repair and tape it back up.
    This^
    So long as you aren't worried about it being pretty.
    If you think it may happen again, you may want to consider one of these: Conntek 10110-048BX Overall 4FT 7-Way Plug Inline Trailer Cord with 7-Gang Junction Box.
    It will make cord replacement much easier.
    That's a pretty nifty junction box, but you can just buy the box and an 8' Bargman cord for cheaper and then not have to worry if only a 4' cord will be long enough.
    Larry
    If the wires are intact in the umbilical I'd look to see if something got pulled loose in the junction box.
    This^
  • I'd just slice open the umbilical, make a repair and tape it back up.
  • I would check for blown fuse in TV.
    Look in owner's manual for location of trailer towing fuses.
  • Double Post:
    Pretty easy to replace, just follow it back to the junction box. All/most of the splices should be made there. You may have to remove a portion of the underbelly to gain access. You can also splice any broken wires where it was damaged. I would replace the cord. When the damage was done you may have blown a fuse or two in the tow vehicle if the wires grounded or arced when damaged resulting in the lights not working.
  • First things first. Is this a motorhome, travel trailer, 5th wheel?
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 10, 2026
