lanerd
Sep 27, 2017Explorer II
Almost all Class C motor homes have a 5000 lbs towing limit. However it may be even less as the limit is determined by subtracting the actual weight (after loaded with equipment, food, clothing, people, animals) from the max gross weight of the motor home. In many, many cases the towing limit will be less than 5000 lbs.
Some Super C motor homes will have more than a 5000 lb limit.
Some gas Class A's will fall into the same category. I think all diesel Class A's have a 10,000 lbs (or more) towing limit....again can be less depending upon the "actual" loaded weight.
Ron
Ron
