carringb
Sep 28, 2017Explorer
GCWR of the E450s is 22,000. Since GVWR is 14,500 you can use the full hitch rating even when fully loaded. Thor motorhomes use an 8K hitch, but if you fully load the MH, you won't quite be able to use all 8k. If you're a stickler about GCWR anyways. I'm not, and I tow over GCWR often, but I did up the transmission cooler size.
When you get into the As, they weight so much, you often run into GCWR limits before hitch limits.
Looking for advice before your next adventure? Look no further.25,192 PostsLatest Activity: Apr 21, 2026
