Monsoon360's avatar
Monsoon360
Towing Heartland MPG with 2000 Ford Explorer V6
I apologize if this has been answered, but a search revealed no results.
I am less than 1.5 yrs from full retirement, and plan on trying to full time in one of the MPG small trailers or similar. The tow vehicle is a 2000 Ford Explorer 4.0L V6 4WD. If I'm reading my manual right, the tow capacity of my vehicle is about 4000lbs. I plan on installing A strong hitch and oil cooler, tranny cooler, anti-sway, etc.
According to my research, the MPGs dry weight at around 2800lbs and GVW at around 3800lbs. My question is, is this set up a viable option to tow something like the MPGs safely given the towing setup? I have no experience towing much of anything. My plan is to boondock the southwest in the winter, with maybe one trip a year back here to Florida.
Anyone have any experience in this area and can share some knowledge? Thanks in advance.
  • jerem0621 wrote:
    Those 4.0 V6's are near bulletproof. It will not win any races but it will get the job done.
    You may be right. I bought the "Exploder" when I was still living in AZ. I have maintained it religiously ever since. 125k on the odometer,and still runs and drives like almost new. Hasn't "exploded" yet. Like I stated previously, I'm not ever gonna be in any hurry, as long as I can tow safely.
    Thanks for the input.
    JD
  • Those 4.0 V6's are near bulletproof. It will not win any races but it will get the job done.
  • Thanks Mike. I know the vehicle is marginal at best without the tow package. I would not even attempt it without. I will most definitely take a look at the Anderson. Thanks again for the info. Speed is not a concern. I will never be in a hurry.
    JD
  • I used a 2000 Mercury Mountaineer (Explorer twin) with 5L V8 to tow a 23' Rockwood TT with slide. Dry weight was about 3400 lb. With overdrive locked out it did the job ok, but just ok. I did not drive over 60 mph, and of course when headed up long grades I would shift down and slow down even further. Typically I'd get 18 mph highway, but 10 mpg towing. Hit a headwind and that went down to 8.5 or 9 mpg. Ugh. I still have that Mountaineer; my wife won't let go of it, so it's her around-town vehicle.
    I think you'd be ok with that rig, so long as you don't want to win any speed awards. Keep it under 60. Make sure you have adequate cooling for the tranny, like you say. Maybe get a Scangauge and plug it into the OBD port under the dash so you can monitor your transmission temp. For that rig I would suggest a look at the Anderson No-Sway hitch; I used one to tow a 16' TT with my Highlander last summer (5000+ miles) and it worked very well, was easy to hook/unhook and has no bars to stow away while unhooked.
Looking for advice before your next adventure? Look no further.25,204 PostsLatest Activity: Aug 12, 2026
