I have a 2019 Ford F-250 and recently purchased a 2021 Salem Hemisphere travel trailer. I’m struggling with the tongue weight. I had a 25’ Cruiser Shadow and no problem there as it had pass thru front...
Is the truck level with this set-up? Yes, then just raise the hitch ball up 1/2 inch, or to the next increment and readjust the WDH. 3/4 ton truck likely unaffected by 25% weight. Move stuff away from the front of the camper to the axles or to the rear, the heavy stuff that is. Any distance you move weight back will lessen weight on the tongue. How does it drive and handle?
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
