mikemc53's avatar
mikemc53
Explorer II
May 24, 2015
towing long TT
I know that the entire towing experience will be interesting for me (basically a rookie)but there are one or two things that I'd like advice/opinions on.
The TT that I am getting is about 35 feet long (Rockwood 8329ss) and I have already gone through any number of tutorials on backing up. I actually think I'll get that part of it - though by no means will it come easy. The part that I am really curious about is the tracking of the TT. When I get it I will be driving home from the dealer and I would think that turning it going forward(right and left) would be a bit of an issue, at least initially. Right turns I have heard are probably the tougher of the two simply because you are turning closer to any barriers. Either way though I have some concerns since I have nothing to compare it to, at least not until I've driven it a few times.
How can one tell when they are far enough into the intersection (or wherever you're turning) to start cutting the wheel? I'm just curious how the TT tracks in accordance with the TV.
One of the things I will need to deal with is once I get home I have the luxury of pulling in since I have a horseshoe drive. That said, the driveway on either side of the "shoe" is not very wide and there is a ditch (culvert under driveway) on each side. I will probably be turning left, which is easier but I still need to be sure I am far enough over so that the tracking of the TT doesn't take the wheels into the ditch. I live on a two lane highway that is moderately traveled - just as a point of reference.
Not sure if anything I have said or asked makes any sense but if anyone has information of the tracking of the TT or simply turning while going forward, I would much appreciate it.
Thanks,
Mike.
  • Try to judge when the rear axle of TV has cleared the corner, then cut as hard as needed. Like others have said, practice and mirrors. It's not as hard as it first seems, just a bit intimidating, but you'll master it quickly.
  • It's very easy. Consider this, take turns alot wider than you think you will need. Reason being you can never have too much room, but if you cut it short, well you will have problems. as far as towing on tight back roads if the truck mirrors can fit so can the trailer. Stay in the middle of your lane and it will track perfectly in the lane. Tight spots like parking lots and the such your tow mirrors are your friend. Watch the tires and keep them away from curbs. Our TT is right at 36 ft and I've never had an issue getting in or out of a spot. Easy for me to say but don't stress. The drive to and from is always part of the fun for us.
  • Take your right turns wide and keep an eye on the wheels in your mirrors.
    Ditto. We had a TT of similar size for 6 years and learned pretty quickly that it does track inside the truck a bit. Practice makes (nearly) perfect! Take it slow in the turns, especially while you're getting used to it.
  • It is really not that hard. Take your right turns wide and keep an eye on the wheels in your mirrors.
  • You are thinking correctly, and seem to understand the problem - which is more than half the battle. If you can adjust your mirrors so you can see where the wheels are tracking it is a big help - especially until you get used to it. Swing as wide as possible, and don't cut the wheels until you can see the trailer wheels are about to pass the obstruction. Also be aware that the hind end of the trailer swings the opposite direction, so make sure you know what is over there too.
    Take it slow and careful, stay alert, and it will come to you in time .....
  • Watching the mirrors and a lot of practice helps. Sadly, there is no way in heck I would ever consider towing a 35 foot TT. Just too unwieldy.
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Nov 14, 2025
