JBarca
Feb 13, 2014Nomad II
nstubbert wrote:
I was told by local trailer business that there isn't a load range D tire in a 205 so I have to go up to a 225 which requires getting new rims.
Maxxis does make a D load range ST205/75R15 2,150# at 65 psi
http://www.maxxis.com/Industrial/Trailer/M8008-ST-Radial.aspx
nstubbert wrote:
I currently have 205/75/15 load range C tires on there right now that appear to be in good condition. My guess is that they are the original tire. I have a 2008 Zinger ZT32QB camper that has a GVWR of 8010. On another forum people have been telling me that I need to upgrade my tires to a load range D tire which means getting all new rims as well and spending about $800 which I don't really want to spend.
They put C's on with a GVWR of 8,010#?? Heads up if you load this camper full it is not hard to have one tire over weight.
Caution on going all the way to 225/75T15's. That size tire is a lot bigger in OD then the 205. And there is also a rim width difference
205 is 27.1" OD mounts on a 5.5" rim
225 is 28.3" OD mounts on a 6" rim
You may have a wheel well issue. Top of tire to bottom inside of fender. Do not know you clearance now. Dexter recommends 3" min clearance, other brands have set up on 2 1/2" and that works but not a lot less. Also check how close the tire is to the frame as width could also be a problem.
And yes, I agree you should have more tire capacity than the stock configuration. If you want to stay on 205 C's suggest to go weigh the camper and get all 4 independent wheel weights. And then only load the camper so the heaviest wheel does not exceed 80% of the 205 C load range. (odds are high all 4 wheels are different weights) Which I am sure is hard to do on a camper as big as yours. 20% reserve capacity on tandem axle setup is now gaining traction to help on the higher heat/side loads due to the tandem setup. Even if you up size the tire load range, still good idea to weigh the camper wheel by wheel.
Hope this helps
John
Looking for advice before your next adventure? Look no further.25,204 PostsLatest Activity: Aug 13, 2026
