lurkerdan's avatar
lurkerdan
Towing Newb, need some advice
Hi all, new member here, apologies for the long post. Thanks in advance for your help!
Buying a new-to-me camper, a Jayco Jay Feather Sport 165. It's got a GVW of 3500, the tongue weight is high because of batteries (I've been told), maybe 500-600? My TV is a 2007 Nissan Frontier Crew Cab, towing capacity is 6000 or so (then reduced a bit by the topper I have on the bed). The trailer has electric brakes and I'm going to install a Prodigy P2 brake controller. The friend I'm buying the camper from uses a weight distribution hitch rated to 600 lbs TW, with no sway control.
All of this stuff is new to me, I've towed a popup before but not had any weight distribution (or any towing issues). There are so many models, with different price points, and I'm just lost. And no idea whether I need sway control too. My local RV place isn't the greatest, they're small and don't have lots of different brands and aren't always helpful, so I'm trying to learn as much as I can.
Questions:
How do I decide between the different brands and styles?
Do I need sway control, or is it even a "want", or just a waste on a trailer this size? It's a huge trailer to me, but I know in the grand scheme it's pretty small.
I'm not a very handy person, so will likely pay for install so it's done right. How much should that cost?
Lastly, if there's something I'm missing, like if I'm going to overtax my TV quickly, please let me know. Also happy to hear any pointers re how this will be different than towing my popup.
  • As far as I am concerned, weight distribution and sway control are an absolute must have.
    Ken
  • While maybe not absolutely necessary, I think you would have a much better ride and more relaxed driving experience with the WDH and one sway bar. Another major difference in towing that and a PU is seeing around it. If you mirrors don't extend in some fashion get some type of clip on mirrors. They are cheap and easy to install.
  • Since your TV is older it needs to have good suspension. Then 60% of the weight has to be in front of the center of the trailer axle(s).
  • If the tounge wt. really is 600# you may be over you receiver rating without a wdh. Check the receiver for a sticker with weight carrying # and weight distributing #. Most times the vehicle can handle more tounge wt with the use of a wdh.
    As for sway control, with a shortish trailer you should be ok with the basic friction bar type. A standard wdh and single sway bar should be about 300$ or so for the bits and peices.
  • Based on my experience with TTs years ago, I'd certainly get a weight distributing hitch and add sway control. If you set the sway control correctly, it will be a lot less nerve-racking when you get passed by a large truck or have side winds.
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Dec 02, 2025
