akguy's avatar
akguy
Towing Saturn 2007 Vue
We are new to this, we have a Roadmaster Sterling tow system. The Saturn manual says to start the car, place in N, then pull the IGN fuse. Then every 7 hours, need to restart the car to lubricate the transaxel. Is there something we can do to bypass the fuse so we don't have to pull the cover off of the car? Thanks in advance. Mike
  • You can run a charge line to the battery fron the MH. You can also start the Vue every 4-5 hours to put a little charge in the battery. Just make sure all your accessories are off. I have run mine for 6 hour withour shutting my remote switch off & it still started. Other than that bit will cause no danmage to the Vue. The new run Recomendation is 5 min. of run & NO reverse or park if you do you are suposed to go back to nuteral & run for 5
  • I have the same car and the same issue.
    Check out this string Clicky.
    I haven't tried to install a switch yet but I intend to, let me know if you find something that works.
    Joe
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
