Mizzouri's avatar
Mizzouri
Towing Terrain Denali
Looking to tow the above behind by Class A. What do I need to know as I have always towed a CRV for 10 years and it is about as easy to set up as it can be. Can I tow it flat? If so, what do I do about the transmission, etc.
Thanks
  • The manual for my GMC pickup explained what was need to tow it. I would follow it as yours could be different than that what was posted.
  • Thank you, that's what we needed. As always, RV.net is most helpful/
  • while not the Denali, we have been pulling our Terrain since it was new. Simple set up procedure as all you have to do is pull a fuse (#34 - I think), put the trans in neutral, and the ignition in the "on" position. There is a max 65mph requirement, but since we only tow at less than that, it's not a problem for us. I have gone over 65 many times (down hill, passing, etc), but typically stay at 62 or 63.
    As for the fuse, I replaced mine with a switch so that it's just a simple matter to flip it and I'm good to go.
    The car has been a perfect toad for us, just the right size, weight, and is comfortable, gets good mpg, and is very quiet. We now have about 80K miles on it with about 20K as a toad. Other than oil/filter change, all I've done is replace the battery and tires (both around 70K miles).....that's it, nothing else. I've noticed that the 2016 V6 comes with a 301hp engine...wow! That's a lot of hp for a 4000 lb car. Ours is the 4 cyl (185 hp) and suits us just fine.
    We chose the Terrain over the CRV for several reason, and turned out to be an excellent choice.
    Ron
  • According to the 2015 Towing World dinghy Guide, it is:
    http://towingworld.com/resources/2015DinghyGuide.pdf
    With the small GM SUV's you usually rotate through all of the gears, put it in neutral, pull a fuse, turn the key to acc and you are good to go. I have a Chevy Captiva, which works the same way.
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Sep 01, 2026
