skipnchar
Aug 21, 2014Explorer
I've towed through the tunnel from both directions dozens of times but towing only around 10,000 lb. Have done it with two different 5.4 V8 Fords, a 6.0 diesel Ford and my current 3.5 V6 Ford and haven't overheated with any of them. Doubt if you'll have any problem with your rig as long as you keep your speed up. Low speeds would make it more likely you'd overheat due to less air moving through the radiator.
Good luck and enjoy the trip / Skip
Looking for advice before your next adventure? Look no further.25,203 PostsLatest Activity: Aug 06, 2026
