jmaotto
Aug 22, 2014Explorer
I just did that in July. I also have a D-max. When it downshifted on the way up I held the rpm's to 2500. No problem and no overheating. On the way down the transmission will select a lower gear as you brake. once it is in the right gear you will not need to use your brakes. Mine held 55 MPH all the way down.
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
