tunaguy's avatar
tunaguy
Towing Toyota Tacoma on Dolly Backwards
I know towing four down is much easier and better but the DW and I have been going around and around about a tow vehicle we both like toyota's
and I will always have a truck so could be an answer. Any issue with a dolly with the heavier end not on dolly? Anybody ever seen or done this? I have a 2013 Baystar 3209.
Thanks for any incite you may hav.
Jeff
  • j-d's avatar
    j-d
    Explorer II
    Toyota quit allowing four down on all Tacos. Dolly mfrs don't like backwards but I think I saw it as alternative in a GM manual for Canyon whatever the new midsize PU is. If you do this YOU MUST USE a special steering wheel immobilizer. Not an OEM lock if it even has one and not some home brew ginny
  • The only insight I can offer is, consider trading your Tacoma for a Toyota that can be towed 4 down or safely on a dolly.
  • It is not recommended, AFAIK, by any dolly manufacturer.
    Yes, I have seen it done. Many times, in fact. No, I have not done it.
    IF the Toyota is four wheel drive, and IF the transfer case has a Neutral position, it might be towable four down. If it is 4X4 it is probably NOT towable on a dolly, no matter which end is on the dolly!
    IF the Toyota is 4X2, and automatic transmission, there might be a lube pump kit available from REMCO that will make it towable four down. There might also be a driveshaft disconnect kit available.
    The owners manual is the final authority on towing, except for lube pump kits or driveshaft disconnects.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 11, 2026
