tunaguy's avatar
tunaguy
Towing Toyota Tacoma on Dolly Backwards
I know towing four down is much easier and better but the DW and I have been going around and around about a tow vehicle we both like toyota's
and I will always have a truck so could be an answer. Any issue with a dolly with the heavier end not on dolly? Anybody ever seen or done this? I have a 2013 Baystar 3209.
Thanks for any incite you may hav.
Jeff
  • j-d's avatar
    j-d
    Explorer II
    Toyota quit allowing four down on all Tacos. Dolly mfrs don't like backwards but I think I saw it as alternative in a GM manual for Canyon whatever the new midsize PU is. If you do this YOU MUST USE a special steering wheel immobilizer. Not an OEM lock if it even has one and not some home brew ginny
  • The only insight I can offer is, consider trading your Tacoma for a Toyota that can be towed 4 down or safely on a dolly.
  • It is not recommended, AFAIK, by any dolly manufacturer.
    Yes, I have seen it done. Many times, in fact. No, I have not done it.
    IF the Toyota is four wheel drive, and IF the transfer case has a Neutral position, it might be towable four down. If it is 4X4 it is probably NOT towable on a dolly, no matter which end is on the dolly!
    IF the Toyota is 4X2, and automatic transmission, there might be a lube pump kit available from REMCO that will make it towable four down. There might also be a driveshaft disconnect kit available.
    The owners manual is the final authority on towing, except for lube pump kits or driveshaft disconnects.
