dhatcher
Mar 09, 2015Explorer
hmmm, well a quick look around a local RV place's website tells me a tent trailer is going to be around 1,200lbs with 200lbs hitch weight and a 19' box trailer is around 2,620lbs with a 335lb hitch weight. Both seem well within the spec of the xterra.
5,000lb max tow capacity
hitch weights seem to be varying from 400lbs - 600lbs depending on hitch type and weight distribution towing? I'm not quite what that means but, I'm guessing that means a little fancier trailer setup (such as the sway control et all).
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Sep 01, 2026
