handye9
Mar 09, 2015Explorer II
dhatcher wrote:
max payload is 1,053lbs
max tow is 5,000lbs
Yeh, I'm on one of the xterra forums but, it is not as well suited for towing info as here :)
The fine print in the Exterra's specs, say that 5000 lb max tow and 1053 lb payload is "When properly equipped". That means factory tow package. Your Exterra does not have that.
In some cases, a factory tow package is more than a hitch, wiring, and tranny cooler. It could also include a gear change in the rear end, upgraded suspension parts, and possibly changes to the transmission.
Also, max tow ratings are caculated with only a 150 lb driver. No passengers, no aftermarket accessories, little tongue weight, and no cargo. As you add weight from these items, your max tow rating and payload are going down, pound for pound.
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Sep 01, 2026
