haggs1974's avatar
haggs1974
Towing with a 31' Class C, frame questions
I have a 2001 Coachmen Leprechaun 305MB 31' Class C on the E450 chassis and the V10. Was planning on hauling some ATV's this upcoming weekend and noticed that hitch rating was for 3500/350 tongue weight. I have read a ton on the reason for this (frame extension/flex ect.) but am curious how weak the frame extension really is. My trailer load comes in at roughly 4000/400 on an open 18' dual axle trailer with brakes on all 4. Is the hitch really only rated for 3500? Looks pretty beefy for just that. Am I in danger of any real frame flex by running with that load? For this trip I am going to drop a 500lb quad so there won't be any issues, but I guess looking into the future, if I add the proper hitch and get some frame reinforcements, will I be good to go or are there still going to be issues? Thanks!!!
  • Thanks for the replies, I had not intended to use a drawbar, just the standard hitch into the receiver. I figure I'm pretty close to what the tow rating is now, and with the frame reinforcement I should be good to go. I know the drivetrain will handle it, just want to make sure I don't start yanking stuff off the walls inside. The PO towed 3000#'s on a car dolly for thousands of miles with no ill affects, I just want to make sure I do everything I can to make it as strong as possible.
  • The frame needs to be inspected. If the coach people used a standard butt weld for extension, it needs to have reinforcing plates added.
    That is a lot of weight to be added. It will take weight off the front end. You may need to get an equalizing hitch.
  • j-d's avatar
    j-d
    Explorer II
    Frame Stretching (wheelbase) and Extending (rear overhang) used to be an ad-hoc thing, done on the whim of the coach builders. But for years now, they are following standards published by Ford. And those standards preserve the OEM rating of the CHASSIS.
    That said, the amount of rear overhang in a 31 ft Class C is a LOT. In our case it's 10-11 feet and our wheelbase is 218 inches. That means it may not be a good thing to apply 500 pounds of hitch ball weight.
    I think that what the 5000 and 7500 pound hitches offer, in addition to heavier material, is more "bearing" onto the frame. And maybe additional bolts, spacers and backing plates.
    Please be sure to NOT extend the Drawbar. The rating is based on a standard length "ball mount" or whatever you call it. Lengthening it or using a Lift/Drop adapter weakens the system.
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Dec 22, 2025
