Convington's avatar
Convington
Towing with a Ford Explorer
Hey guys,
I was pointed over here by another forum because I'm getting a bit of conflicting info.
I have a 2015 Ford Explorer Limited with a V6 3.5L engine. I do NOT have the Ford Towing Package on it. I do have a CURT Class III hitch purchased from eTrailer about 5-6 years ago. I have only used that hitch so far to pull a Canoe.
Looking at Travel Trailers and see that most of them are running anywhere from 3500# to 5000# for what we want.
My Ford dealer, when talking to "the hitch guy", says that even with the 3rd party hitch my vehicle can easily pull 5000#. The other forum has information that says you need the Ford Tow Package to get that rating.
I definitely want to be safe, not cut the life short on my vehicle. Any idea what my vehicle can safely pull? And would I need anything additional to pull a travel trailer safely?
Thanks in advance!
  • Wife wants to get (or rent) a 4000#-ish Travel Trailer, basically. Her vehicle is a RAV4 - so the Trailer would be driving that thing :) So - my vehicle is the only option. Looking to drive pretty far with it also - about 800 miles one way. So expecting 2000 miles with whatever camper we either get or rent.
  • can likely pull around 5k. would be more worried about what it can carry and what it can stop. what are you looking to do?
    for what its worth i own a 2017 explorer (also with the NA 3.5) would tow a small popup, fishing boat or a utility trailer with it without any worry. Would NOT dream of pulling my camper or my boat with it.
    With no factory Trailer Tow Package, I would not go over 3500# !
    Research what are the difference between standard and Tow Package. Likely it is a larger radiator and transmission cooler. You can have these installed.
    Anything over 3500# need electric brake, so a controller and appropriate wiring and 7 pin trailer connector are also required.
    All of this adds up quickly. It might be time to consider a newer ride with the factory Trailer Tow Package ! The 2020MY Explorer switched back to RWD/AWD which is much better for towing.
Looking for advice before your next adventure? Look no further.25,163 PostsLatest Activity: Sep 05, 2025
