trnfla's avatar
trnfla
Towing with engine running?
Hi, I have a 2006 Buick Rainier AWD. According to Remco I need to install a transmission lube pump to flat tow. $895 plus six hours labor to install.
My question is I read on their QA page that if the pump fails while towing to start the vehicle and let it idle while towing.
So if that would work, I am thinking that for the few times I would be flat towing (max 2 hours each way per trip) could I just start the vehicle and put it in neutral for the trip?
Does anyone do this?
Am I crazy?
  • Hi,
    One problem with letting a engine idle for a long time (like the 2 hour drive) is the quantity of oil going up to the valve train. It is just not as much lubrication as a engine running 2,000 RPM or so. But the oil pressure is fine, just the gallons per hour going up to the top end is less than normal.
    Fred.
  • Wow. Now that is some serious dedication on towing a car that is not towable 4 down! Interesting that it can be done.
  • I do this all the time with my 2005 Ford Focus. Remco and Ford say it is not tow able. I have been towing it since 2009 and now have over 104,000 miles on it with no problems. Last fall I sent in an Oil Sample to Blackstone Labs and they said I should change my oil in the next few thousand miles as it is approaching the limits on some tests. This is the original Transmission oil in the car when I bought it new in Feb 05, Ford recommends 30,000 Oil Changes in the Transmission. One thing I did do was add an additional Oil Pressure Switch to the engine and ran the wires up to a Power Plug in the coach drivers bay. I plug in an Amber Magnetic Tow Truck Strobe light and when the engine is not running the light flashes. This will warn me if my engine quits and allow me to pull over before I ruin the transmission. Never has quit on me yet and always reminds me to start the engine before I roll. In the winter I use the Strobe light on my Tractor when I am moving Snow so anyone will have a chance of seeing me after dark. Good luck and enjoy the towing.
