Just commenting on tires and towing HEAVY for 'any' TV's ratings...
I have a 'half ton' C10 Silverado (1980) with after market alloys (8" rims) and
LT tires (33/12.5R15LT load range 'C').
It yaws when towing heavy and the main reason has to do with the tire/wheel
setup
Sidewall bend-back is the main issue. I know it. Live with it. Not worth going
out and buying new wheels for a 33 year old beater truck (that used to be a high
end option package...Silverado...and the HD version of it's time)
It has 1 ton helper coil springs on the rear axle. When a pallet of wood pellets
(about 2200 lbs), some busted bags they toss in for free total around 2,800 +/-
the rear only drops about 2 inches or less
It yaws hauling that load without anything being towed.
Load range C (6 ply rating) is down in the load range of a 'P' class tire.
Married with too much sidewall bend-back...it has the tire roll over, even when
going straight when something pushes the side of the truck...like the bow wave
from a big vehicle either coming or passing.
Helps if those tires are aired up to the mas listed on the sidewall...35PSI
which is 'P' class territory
This is only part of the whole system that manages yaw and trailer sway.
Why my Suburban has 10 inch wide alloys with LT265/75R16E's. 265 / 25.4mm = 10.4
inch wide tires on a 10 inch wide rim. So little to almost no side-wall bend-back
That means that setup has almost no side to side give from the tire/wheel combo
It also means the slip angle is much, much less than if that tire were mounted
on it's recommended rim width (IIRC 8-9 inch). The sidewall does NOT have much
give or any give at all
Easy to check, even at a dealers showroom...
Push the rear bumper sideways. Time it to that vehicles natural harmonics and
you can get one to actually jump off of the tire pads to tile that many have
Have had that discussion with a salesman who was trying to convince my friend
that there is no difference between 'P' class and 'LT' class after I told my
friend in front of him.
What I didn't mention was that the 'half ton' suspension also contributes, but
he made me mad, so a gosh darn....I forgot that...
It was a full sized 'half ton' SUV
Think that is sensation you (OP) have described...that yawing of the TV
