spoon059
Jul 20, 2017Explorer III
DownTheAvenue wrote:bikendan wrote:
As long as your Taco has the factory tow package, you should be fine.
And if it does not have the factory tow package, what then? The tow package includes a receiver hitch, wiring for the trailer connection, higher amp alternator, and bigger capacity battery. So what! All can be added aftermarket!
If he doesn't have the factory tow package, he should consider adding it... then he WOULD have the factory tow package.
Unless something changed, it also has a transmission cooler, oil cooler and power steering fluid cooler. Yea, they can be added but that's a lot of work. Also the newer Tacoma's have an electronic trailer sway control system. Not sure if that can easily be modded after the fact.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 10, 2026
