Bheffington's avatar
Bheffington
Towing without a W/D, 7K trailer, Ram CTD 3/4 ton
Im moving about 350 miles next week. I need to drop the front of my trailer about 2 inches but have ran out of room on my drop hitch. No where near me has a WDH drop long enough. But I can get a standard 8 inch drop locally. This will make my trailer level but Im concerned about not having the WDH. Do I really need it, pulling a bumper pull 7K pound trailer with a 3/4 truck?
  • You'll probably be over the weight rating of the hitch, since you will have around 700 lbs minimum tongue weight. Of the choices, I would go over the weight rating rather than try to tow a trailer with too light a tongue weight.
    Brian
  • Thats a good point. Ill see if I can find a scale near by. Ill also look up the ratings without the WDH. I had a little sway with the WDH and sway control, and I think it is due to the tongue of the trailer being 2 inches high. Ill get it weighed before I head out, and move stuff around to make it right. Thanks for the insight.
    Probably. Make sure the trailer is properly loaded so that there is adequate tongue weight, but don't put anything in there that isn't needed, so as to keep the weight down. If possible, stay on smooth roads, and watch your speed. 60 MPH is likely more than enough.
  • It depends on the receiver rating on the truck and the actual tongue weight of the camper. Receivers have 2 ratings one without a weight distribution hitch and one with.
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Dec 22, 2025
