What is the difference between a flow through and a non flow through tire pressure monitoring system (besides price)? Is one system better than the other? Lakeside
I've got flow through sensors on the rear and non-flow through on the front. The non flow throughs on the front are due to the larger size of the flow throughs, they will not fit through the stem opening in the wheel simulator. This all works out fine, I am adjusting tire pressure in the rear much more often than the front. One sensor in the rear has low flow but it may be due to a blockage in the solid metal stem it is attached to.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 13, 2026
