I recently purchased a TST tpms system with flow through sensors. I now need metal valve stems for the trailer and the truck. Putting metal valve stems on the trailer is no problem but the truck is a...
Or stop looking for a solution to a problem that doesn’t exist and use the perfectly good TPMS system that come with your vehicle that you can likely also watch in real time if you switch to that screen and watch it instead of the road.
Besides you will likely get an error message every time you start the rig which you may not have or want the ability to bypass. As well as you’ll have the low tire pressure idiot light forever guaranteed. Like taxes.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
