I recently purchased a TST tpms system with flow through sensors. I now need metal valve stems for the trailer and the truck. Putting metal valve stems on the trailer is no problem but the truck is a...
Flow thru=more potential for leaks. At least you’ll “know” it sucks and your tire is going flat I suppose. There’s a reason that Schrader valves are normally closed…..because they’re supposed to be to NOT LEAK! Best way to not have a flat on your truck is don’t mess with what’s there….
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
