Miles_Away's avatar
Miles_Away
TPMS saves the day!
I was towing my rig north bound on I-75, just north of Macon, GA when I heard that dreaded "beeping" sound. I looked at my Pressure Pro TPMS and it showed low air in the left front trailer tire. I put on my flashers and pulled over before it went totally flat, saving the tire and avoiding damage to the trailer. After putting out my safety cones, I got to work. Fortunately I travel with a cordless impact wrench, so I had the tire changed and was back on my way in 15 minutes. I couldn't get very far off the "fog line" because of the narrow shoulder, but the flashers and cones helped to move most of the drivers over a lane and give me a little breathing room. The only close call came from another RV'er who apparently doesn't under stand the concept of giving a disabled vehicle a little breathing room. By the way, there was nothing wrong with the tire (Maxis), the valve stem failed.
  • Miles Away wrote:
    Ductape wrote:
    Rubber valve stems?
    BRASS
    In what way did the valve stem fail?
    Were they the OEM valve stems that GM uses?
  • It's nice to hear some good news about a TPMS! Glad the situation turned out okay for you.
  • glad it ended so well....15 min to change a tire on an RV...Nascar Pit crew has nothing on you. happy trails!!
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 16, 2026
