mrkoje
Jun 28, 2016Explorer
Technically the answer would be no you cannot integrate the RV TPMS into the Ram onboard computers etc...
However with a lot of customization the uConnect 8.4 display could be "hacked" to display what ever you want including the readout from an aftermarket TPMS system. Essentially you would have to rewrite the system firmware with an aftermarket or modified version to allow the use of additional inputs. There is a software solution readily available I believe it's called uConnect Lockpick. With the new firmware you would then be able to tie in the aftermarket TPMS readout into a display on the Ram screen.
This wouldn't be a novice DIY job that could be done in a few hours. I know I could get it done but the return/reward for getting it to work would not be worth the time spent in my opinion.
Hope that doesn't let you down too bad! I would just stick to a solid aftermarket system with its own display or alarm that chimes if there is an issue.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 13, 2026
