bluka43's avatar
bluka43
TPO Roofing Adhesive???
Has anyone had any experience with the "fleece backed TPO roofing" membrane? (I never dreamed that I would see a fleece backing under the TPO when removing it). I've had to pull back about a 5 ft long x 16 inch wide section of my TPO roofing to make repairs to a minor leak in the back corner. After the repairs are made I will need to bond the TPO membrane back to the substrate which is 1/2" OSB. Any suggestions or recommendations as to what kind of adhesive I should use?
  • Thank you all for your suggestions and replies. I did call Dicor and asked for their answer...naturally it was to use their product. To make the small bonding that I required, which was approximately 36" long by 18" wide, I didn't want to purchase a gallon of their adhesive. It wasn't the cost as much as that the remainder, would in all probability, go to waste. What I did do was research all of 3M's spray on adhesives and came up with a winner....that being 3M 90. It worked out perfectly for my "fleece backed TPO", by spraying it on both the fleece and the OSB. I let it set up for about 2 minutes until tacky before bonding the surfaces together and then rolling it with a rolling pin. It came out great.
  • had the Dicor Brite-Tek installed on our rig aftyer a tree damaged the roof.
    To me it is much quieter when hit by heavy rains. I think the backing acts to absorb or cushion the impact.
  • bluka43 wrote:
    Has anyone had any experience with the "fleece backed TPO roofing" membrane? (I never dreamed that I would see a fleece backing under the TPO when removing it). ?
    KZ used it for a while.
    bumpy
  • I did the same thing on my sons TT. We used the dicor adhesive. It had an inconsistent bond but maybe we did it wrong. Per all the recommendations and even Dicors recommendation we used the Dicor adhesive.
    So this spring I had a small TT that I wanted to put an epdm liner on. I didn't want to use the dicor adhesive so I started researching epdm and found that it's normal to use contact adhesive. At that point I contacted Dicor and asked why they always recommend their adhesive and could I use contact cement. She said yes I could use it and the reason they dont recommend it is not because it will eat the liner, it's because when the two surfaces touch you better have it right. Well no doubt, that's how contact cement works and yes I could imagine people having a hard time with it. I had the liner situated and started at the center and glued about 2 feet back on both surfaces. I let it set up and carefully worked it back, then I repeated it with another 2 foot section until I reached the back of the TT. Then I worked toward the front. It came out smooth as a babies butt. It was perfect with not one bubble or spec in it.
    So you have tpo and maybe they will say that contact cement is not compatible with it? Call Dicor and explain it in the context of how I described it and see what they say.
    Contact cement is $10.00 a qt. Far cheaper.
    His Rockwood 2008 had a small cut under the ac unit that was there from new. It also had a very small over cut when the razor knifed around the vents. The Dicor missed it by a quarter inch. You couldn't see it unless you got down there and tried to spread the tpo with both hands. It was not easy to see and easy to miss when touching up the dicor. His tpo was also felt backed and sucked water in and raised the plywood by the vent. Felt back gives it a nice cushion but when you get the smallest cut it sucks water in like a sponge.
  • I would call Dicor and ask them. You will definitely get the correct answer.
    Bruce
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 16, 2026
